k9jadon's avatar
k9jadon
Engine Temp how hot is too hot?
So I was just wondering what any of you guys think about this? A few years ago I went camping in the Eastern Sierra Nevada. A place called Tuff Campground. I drove an all stock other than a 4in turbo back exhaust '05 F-250 6.0 dsl and pulled an approx. 10k lb fifth wheel. My question is this, When climbing a grade that is approx. 6% for about 8 miles with ambient air temp hovering around 100*f how far would you want or allow your temp gauge to go b4 pulling off and allowing it to cool off? 1/2, 2/3 , 3/4 or until the light comes on? I kept the boost pressure at or near 20 psi and this formula translated to climbing the grade around 32-35 mph, I think it was running around 3000 rpm or so, and the temp gauge remained for the entire climb at its normal position, it never moved, could I have pushed the truck harder? Is the cooling system designed to run for long periods say like 15 minutes or so at the 2/3 mark or higher on the gauge? I am sorry I do not have actual water temp numbers since my gauge is stock, so I have to give points of reference on the gauge as a description. Any thoughts will be appreciated. BTW I am not looking to drag race up the hill, I just want to know if my truck can handle more?
  • 210 is as high as I would want to get on the climb you described.
    I'm guessing...on your gauge (if it's accurate) that would be just under 3/4...220 would be 3/4.
    Stock gauges aren't always accurate. In my old truck the gauge was 20 degrees low. I put in an aftermarket gauge to get an accurate reading.
    There is a Royal Purple product called "Wetter Water" that works well. It helps to keep coolant temp at lower levels during climbs.
    In my 2007 C4500 Chevy (Duramax & Allison) the normal temp is 180 and I've seen it hit 195 on a 6% grade towing my 15000lb 5th wheel in near 100 degree outside temp. That was in second gear at 40 to 45MPH.
  • When my temps get over 200 degrees I start watching closely. With a V8 225mis getting close. With a 6.0L Ford good luck!
