Lynnmor wrote:
Snip...
Disregard the advice about tightening the handle extremely tight, that will do nothing. I think that this is the reason that folks need to move to a system that takes their actions out of the equation. Adjust the bolt just like the sticker next to it says. Snip...
That sticker will say to tighten the handle as far as it will go and then back it off to be parallel with the A frame. Doing that will put maximum pressure on the device and the setting will be consistent every time you use it. The handle is, as already stated earlier, an "on/off" device.
The adjustment of the pressure is done with the small bolt located beneath the handle. That should be adjusted in 1/4 turn increments until the desired amount of sway control is accomplished. This advice is also printed in the manual and, if necessary, I can copy/paste the actual language from it.
Hope this helps a bit.
Barney
