waynefi wrote:
jerem0621 wrote:
If it ain’t moaning it ain’t working!! Tighten the adjustment bolt 1/4 turn at a time. You can also tell If you start getting some wiggle between the TV and the TT when vehicles pass you. When the hitch is dialed in and the sway control is working then the rig should feel rock solid together.
Thanks!
Jeremiah
Well, mine ain't moaning anymore, so maybe it ain't working anymore. It was noisier when it was new, so maybe it has worn down. But the rig still feels fine when a semi goes by.
I've tightened it up a quarter turn, we'll see how it does. Then maybe I'll try a swerve test, with one hand on the brake controller.
Thanks for the suggestions.
Actually it should only moan when it is wet.
