karlrmac's avatar
karlrmac
Equal Chain Setup
Hello,
I've looked and may have missed something, but when i hook up my TT to my TV, i always have a hard time matching the number of loose chain links. The TV passenger side is the toughest to get on and the TV driver side is very easy. I want to get 5 links loose and its very hard sometimes. Any ideas?
Also, do the chains have to be the same?
Thanks,
Karl
  • Your post is vague, but I will ASSUME that you are not referring to the trailer safety chains.
    In my oh so humble opinion...
    ASSUMING all things are equal (same U bolt, same chain & brackets parrallel on trailer frame) Both sides of a WDH should be hooked to an equivalent chain link. Otherwise you risk one bar being tight, the other being a bit loose....which means the tight chain is taking the brunt of the load (maybe exceeding it's limits).
    My driveway is less-than-level, and I have to lift the trailer higher in order to get the passenger side on without overly straining myself. Try lifting the nose of the trailer in order to get the high side first....should make the low side real easy to attach.
    Check to see if you are aligned to the trailer when hooking up. Having your TV slightly ****-eyed will mean that one bar is being pulled forward, while the other is being pushed backwards. It may not seem like much of a difference, but those chains are under extreme loads. If your brackets are set up in a fashion that the chains are less than verticle (pulling a bit forward or backwards)this could align one chain, while making the other further away. AGAIN...raise trailer high enough to safely attach the tighter of the two, the other one should be easy.
    Hope this makes sense....hope it helps.
    EDIT: Guess I shouldn't have said ****-eyed. In future post I must remember to use crooked, not stright, bent....or anything besides ****-eyed.
    Will it work without the hyphen... cockeyed.
    MORE EDIT: IT WORKED. Must have been the hyphen that was being BANNED.
  • Are you raising the tongue with the jack up above level after connecting the ball, before attaching the bars?
  • The 5 links loose sounds like a lot, but if you followed directions is what matters. The spring bars may be slightly different and the chains as well. I adjusted the u-bolt to help compensate for the difference on mine. After the first bar is installed the effort for the second one will change. No, they don't have to be exactly the same.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
