TKW
Nov 11, 2017Explorer
Timber Ridge TT's frame sits high. I Know so b/c I just set up a Equal-i-zer hitch to my Timber Ridge 240rbs last month. The top of my coupler measured 30" from ground. In my mind, a bottom mounted coupler, instead of this more common top mount type, would be more suitable in this application.
I had a fairly tall shank left-over from my last TT so I didn't order a shank with my hitch. To match the coupler, I have to set the hitch head to the max rise position of the shank. However, at that height, the hitch ball will dent my tail gate at the open position. I settled with one bolt hole lower than level. When it was all said & done, the TT frame was 1 1/4" lower at the front. It was hardly noticeable by eyeballing. To me, that's close enough.
The receiver height on every truck is different. I can only guess my 4x4 truck has a higher receiver than your 4x2 truck. Anyhow, as other member suggested, a taller shank is in order. I would follow the hitch manual and measure the actual height differences between the coupler and receiver to determine the shank rise required.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 18, 2026
