Hannibal
Nov 12, 2017Explorer
Baja Man wrote:
The tallest setting on shank (ball height) was 2" below trailer height.
Should I add washers or is a taller shank in order?
I agree with Barney. The ball should be 1"~ higher than the coupler with the trailer level on level ground. A taller shank will get you there. The other consideration is, will you still be able to lower your tailgate with a taller shank without contact if that's important to you? If so, I would leave it as is. The only problem I see with that little bit is camping overnight hitched up and sleeping downhill.
I wouldn't over stress the spring bars and trailer A frame trying to compensate for a short shank. I have my angle set so that the bars are parallel to the A frame. With the tongue raised just high enough to put upward pressure in the receiver, I can install and remove the bars by hand. This returns half the squat in the rear and half the rise up front.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 18, 2026
