Baja_Man
Nov 14, 2017Explorer
Hannibal wrote:
This why you set the ball 1" higher than the coupler of the level trailer on level ground. If your truck settles 2" and the WDH bars bring the rear back up 1", you should be back to level on the trailer. If the tongue weight sits the truck down 4" and the bars bring it back up 2", then set the ball 2" higher than the coupler of the level trailer on level ground.
The EQ manual stated that both truck and trailer needed to both be at same height when beginning set up.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 18, 2026
