BarneyS
Jul 02, 2015Nomad
lbrjet wrote:
Four washers is the minimum according to the manual.
Here is what the Equal-i-zer manual says.
"Start with 5 spacer washers for
longer wheelbase tow vehicles like pickup trucks, and 4 spacer washers with
shorter wheelbase vehicles like an SUV." That is not the minimum. You can use less if necessary. The reason to start with 4 or 5 is that amount usually results in the bars resting flat on the L brackets when they are on the recommended hole for most common trailer frame widths that would be pulled by those types of vehicles.
You do not want the WD bars meeting the L bracket at an angle because that means the mating surface will be on the edge of the bracket instead of flat on it. This reduces the effectiveness, makes more noise, and can possibly damage the L bracket.
Barney
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
