DutchmenSport's avatar
Jul 01, 2014
Equal-i-zer hitch ... is this normal?
Noticed on this trip that my Equal-i-zer hitch is making a lot of groaning and popping noises. I purchased the hitch system this last April and never noticed noise until this trip. The ball has grease, I'm pretty sure the groaning is from the bars sliding back and forth on the L support they rest on. The paint is now rubbed off where they move back and forth. Of course the groaning occurs only when turning.
At first I thought, the spot where the bars and and the L touch to put sone grease there. I'm pretty sure that would take care of the noise. But if I do that it will reduce the friction which will make the anti-sway from being effective.
So my question is, for you Equal-i-zerr users, is this common, normal for all the noise when turning. If so, I can live with that, because I do know where it's coming from. But if there is a way to quiet it down, what do you do (and still retain the integrity of the anti-sway friction feature.)
Suggestions, comments appreciated. AND NO I am not purchasing a different hitch system. This one works VERY well. I just don't know about the noise if this is normal.
  • The noise you speak of is pretty standard as reported by those using the Equal-i-zer WD/SC hitch, greasing where the spring bars lay would decrease anti-sway properties. We use a Reese version of the Equal-I-zer and it to makes a bit of noise while turning or backing up which I deem as normal.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
