MeandMyLabs
May 12, 2013Explorer
I purchased a 12000 lb Equal-i-zer brand for the trailer in my sig last December. I installed it according to instructions myself on my previous truck (F150) and then again on my present truck (Silveraldo 2500 HD). I have been very pleased with its performance on both vehicles, especially noticing a large difference after switching hitches on the F150. I would suggest erroring on the heavy side because the hitch can always be adjusted lighter but you cannot increase the stiffness of the bars without changing them to a higher weight. For my trailer, I was on the border between the 10000 and 12000 lb setup and so I opted for the heavier.
If you decide to install yourself, you will need to torque some of the bolts very tight including the hitch ball which requires a 1-7/8" thin wall socket. I took my hitch to a local agriculture dealer and they torqued it for me for no charge...pretty nice. Otherwise you might need to purchase tools which you might not have.
I hope this has been of some help. Good luck.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
