Ron_Gratz
May 13, 2013Explorer
beast_3 wrote:Two reasons come to mind immediately:
Is there any reason not to buy a hitch with the highest weight rating, even if it ends up being 300-400 pounds higher than the actual tongue and total TT weight?
Thanks!
1) WD bars which are too stiff can result in a ride which is too rough.
2) WD bars which are too stiff potentially can cause damage to a TT's A-frame.
It's relatively simple to calculate how much load must be applied to a WD bar in order to transfer a desired amount of load to the TV's front axle.
The problem is that no WDH manufacturer actually tells us what is the maximum load that should be applied to a bar.
Some people tend to assume that a 600# tongue weight requires WD bars rated for 600#. Others recommend going using bars the next size up.
Unfortunately, for the Equalizer, the next size up from 600# is 1000#.
So, how do we determine how much load a WD bar is actually designed for?
It's probably safe to assume most WD bars in use today received their "ratings" back in the late 1950s or early 1960s.
The typical "tow vehicle" of that period was the family sedan with a typical wheelbase around 120" and a typical rear overhang around 60".
The ball overhang might have been about 70".
Back in those days of "equal squat", the WDH might have been called upon to transfer enough load so the front axle was carrying about 25% of the TW, the rear axle 35%, and the TT axles 40#.
Assuming a 20' TT with a ball to axles distance of 180", each WD bar would have been loaded to about 720#.
So, if we can assume a 1960's WD bar rated for a 600# TW actually is intended to carry a load of about 720#, we can fast-forward to 2013.
Today, a WDH normally is expected to restore to the front axle a load which is equal to the amount removed.
For a 600# TW, the WDH now might be required to transfer 250-300# to the front axle.
This would require a load of about 130-150# to be transferred to the TT's axles.
Assuming today's typical TT has a ball to axles distance of 240", each WD bar would have to be loaded to about 560#.
If this scenario is realistic, it appears that a 600# TW, with today's WDH usage, would generate a bar load which is about 80% of the load generated with the 1960's usage.
Or, another way to look at it is that a 750# TW and today's WDH usage would generate a bar load equal to that produced by a 600# TW with 1960's WDH usage.
Obviously, the foregoing involves many assumptions.
My point in presenting this analysis is to give background for my OPINION that there is no need to jump to a 1000# bar "rating" if you know that you will have a 650# tongue weight. Bars with 600# rating should be sufficient.
I would rather be 10% over a WD bar rating than use a bar which is rated for more than 50% above what I need.
Ron
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
