Jayco23FB's avatar
Jayco23FB
Equalizer hitch with sway control
I would like to get a new equalizer hitch with sway control.
TT wt. = 6600 lbs.
Tng wt. = 680 lbs.
Add wt. = 100 - 200 lbs
total TT length = 26.5'
I do not want a friction control device. I also want a system that is not overly complicated to set up or hook up. I only notice sway when traveling on the freeway (60 mph) and when passed by a semi. Lastly my Silerado 2500HD has a 2.5" hitch I would like to use the hitch without the need of a reducer. I would love yur input and recommendations.Thank you.
  • I have not installed the friction sway on my new TT yet and might just wait till I need it. If there was a system much better than the old round bar and friction anti sway I would consider it as long as it is easy to hook up.
  • Having towed the exact same trailer with my 03F150, 07 Dmax classic and now our 12 F150, buy the Equa-lizer with the 4 point sway, set it and forget it. We have over 30k km of towing and have never had a problem with wind or semi's.
  • Upon cleaning up my old round bar hitch I see the holes that the bars go in are somewhat worn. Might be looking for a new WD hitch with sway cont. Reading that the Equalizer is noisy and stiff and the Dual cam is tricky to get set up right and noisy. Others are big bucks. So what to do?
    I would look at some of the other WD hitches that include sway control in their design.
    Some examples would be Husky, Blue Ox, and Andersen. Those are no more expensive than the ones you mentioned.
    Barney
