Gold's avatar
Gold
Escalade/Denali or Suburban 2500
I’m considering buying a 2010 Escalade/Yukon XL Denali or a similar year Suburban 2500.
I currently have a great running 2003 Suburban 1500 5.3L 285hp autoride which I’ve upgraded with stiffer z51 springs and has fresh GM autoride shocks. I recently obtained a 20 foot v-nose toy hauler, I’m guessing the weight of the loaded trailer (and people/cargo in the suburban) is 6,000 lbs. Fortunately it’s very level and stable when towing because I can’t have a WDH as the v-nose on the trailer prevents a WDH from being used.
My issue is that I simply run out of power with the Suburban. I can’t use cruise control on the highway as just the slightest incline (or even the wake of a truck) will cause the Suburban to gear hunt, and even when not using cruise control it’s hard to maintain 60 mph.
I’m considering either a 2010 Escalade ESV/Yukon Denali XL (both have 6.2L 402HP 1500 chassis), or a similar year Suburban 2500 which has the 6L 355HP 2500 chassis.
I’m more attracted to the Escalade/Denali as they are quite a bit less expensive and exponentially easier to find (and have a bigger engine and 47 more HP), but can it tow ‘as fast’ as the Escalade/Denali despite it having 47 less HP that I should consider it. Thank you in advance for your insight.
  • Burb 2500 all the way towing 6000lbs. They could be ordered w 3.73 or 4.10. It's worth the extra $$ to have the heavier running gear.
  • I tow my travel trailer with a 2000 Suburban, 5.3, Sumo SuperSprings. It's 5800 dry. I figure, without water, I'm still plenty over 6,000 Lbs. Yeah, it's slow going and I drive it easy. I have looked at 2500 series Suburbans, Avalanches, etc.. With the 8.0 they are a little cheaper but, I don't want that engine. The 6.0 versions can be quite expensive, considering year and mileage. I keep kicking myself because I saw a 1996, 2500-454 V-8, 4x4, low miles on a lot a couple of years ago reasonably cheap. And it was as shiny as a new penny. I passed on it. That 454 is a hoss and would have been a great vehicle for towing. Not much of a daily driver mind you.. I keep passively looking. And I haven't ruled out a 3/4 ton Chevy or GMC van with the 6.0.
    BTW, the chassis does fine. No complaints with the WDH. And, if you could ride around at 3200+ RPMs the power would be fine..
  • falconbrother,
    Here is my 1996 GMT400, K3500, 7.4L, 4.11, Suburban's picture. Tongue-on-cheek K3500 because ordered it with the F60 option. Which is snow plow prep package, which gets the 1 ton front suspension torsion bars and since the rear end is the same as the 1 ton dully of that year... :B
    Sold the boat and only occasional borrow a TT to camp with
    Itching to 'have' to rebuild the engine and then an of course the tranny & rest of the drive train. Plus 4.88 or 5.xx front and rear diffs with a GearVendors 0.75 over drive to give an 8 speed setup.
    If the OP doesn't mind an older Suburban, there are a few out there that were still truck like.
    GMT400 has a few things that need to be addressed and improved. Mainly the brakes, but after converting mine to the same rear dually brakes...nose bleed braking. Even touchy, which is okay with me
  • GMT400s are still best of the breed on several accounts, IMO. Anything older will require this n that for repairs. Since "there's no demand" for HD suvs as some claim, you'd think they'd be paying you to take them gas hogs, but around here, a Burb like BenK's with low 100s for miles is a $10k rig.
    IMO, the GMT 400s generally didn't have any fatal flaws (if you don't get into the 6.5 diesels...) and relatively easy to improve certain aspects, like the dually rear wheel cylinders. I did that cheap mod years ago, it was great.
    Only thing better is if you could get a GMT 400 big block K2500 burb with the NV4500 that you could get in the pickups!
