popeyemth's avatar
popeyemth
Eternabond cleanup
Finishing up my Shadow Cruiser pop top truck camper roof rebuild and need advice on cleaning the Eternabond tape
Pressed it down (maybe TOO much ) and some of the adhesive has slightly oozed from the edges .
Anybody know how to clean that up?
Was thinking maybe an acetone wipe but don't want to hurt the tape.
TIA,
Mike
  • I'd consider using Eternacaulk or a clear (not silicon) caulk on the edges so they don't get dirty. Dirty edges don't affect functionality, just looks.
  • thanks for the replies.
    i made the edges look worse than necessary because I had a six inch end cap to cover and only two inch tape so there's a lot of edges on the overlaps.
    i'll just leave it alone.
    thanks again,Mike
  • Edges can be cleaned with acetone or mineral spirits, just apply with a rag and don't pour directly on the rubber roof. It will not hurt the Eternabond. Website recommends applying a thin bead of sealant along the edges to seal them. They have their own "M-1 sealant" I have used dicor lap sealant successfully. Also states it keeps the edges from lifting in the wind. Never have seen that happen, don't want to.
  • I just would not worry about the ooze, it won't cause a problem - I think it means you've installed it correctly. Any solvents to remove the ooze may loosen more than you want to loosen.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
