Halmfamily's avatar
Halmfamily
Eternabond Primer
Do I need to use the Eternabond Primer prior to using the tape? Can I just thoroughly clean the area with alcohol and lay down the tape, roof is only 9 months old. I need to cover the seam on the front where the cap meets the roof, apparently someone had a bad day sealing this area. Any other tips would be appreciated also .
  • No. You don't need the Eternabond Primer.
    Just use mineral spirits or acetone. Clean the area well before applying.
    You do need a roller to apply the Eternabond properly.
    Eternabond recommends acetone or laquer thinner (which I use) when you've just removed old Eternabond tape and the old tape's micro sealant still remains.
    Check out Eternabond's video library.
  • Acetone is like killing ants with a hammer. Most use mineral spirits. You need it clean you don't need to remove paint or melt rubber.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
