UsualSuspect
May 26, 2014Explorer
prsturtz wrote:
When I test my e-brake it should test 3 times, now it only tests 2 times and goes red. Cannot use it. please help if you have any ideas/ Pat
The only time mine has done that is if I do not follow the how to connect it properly directions. If you are not sure if you hooked everything up in the right order, just disconnect the firewire and the power cable. let the sir out, and start again.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
