bschmaus's avatar
bschmaus
Expectations for Towing with Toyota Highlander XLE AWD
I'm planning to purchase my first travel trailer and am looking for some guidance from the community about realistic towing expectations for my XLE AWD Highlander (2018).
The XLE AWD Highlander has a trailer weight rating of 5000lbs and a cargo carrying capacity of 1300lbs. Using what I believe are conservative estimates with the following calculator (link below) I am thinking that a trailer with a GVWR of less than or equal to 4000lbs should be fine.
http://www.towingplanner.com/Calculators/TowingPayloadEstimate/?ccc=1300&dw=170&pw=340&hw=50&tc=50&bd=200&ct=TT
There is one trailer in particular that I've been looking at, the Camplite 16bhb model (https://www.livinlite.com/products/camplite-travel-trailers/CL16BHB.html), that I'm not sure if I could tow. The dry weight is sub 3000lbs but the GVWR is 4400lbs. I don't expect to load the trailer to its GVWR so my main question is: is it reasonable for me to assume that I'd be able to comfortably tow the Camplite with the expectation that I would have it loaded at 4000lbs or less?
  • I believe that 5000lb tow rating is dependent on vehicle configuration. Better check that yours meets the specs for that higher rating.
    While the Highlander may be able to "tow" the trailer you mentioned (nice trailer by the way!) I am not sure you will be satisfied with the results. The Highlander is a SUV and primarily a people carrier and not designed to be a tow vehicle. The frontal area of the trailer will get you more than the weight.
    I would do a lot more research before I plunked down the amount of money they want for one of those. :)
    Barney
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
