SCVJeff
May 18, 2016Explorer
One thing no one has mentioned is that on the interior sidewall, the impression of the cords is obvious. In order to prep that area they use an extremely hard wire brush to grind it flat for proper seal. Easy on the tread wall, it's 3/8"+ thick and the cords are buried deep. If you were to use that proceedure on a sidewall, you are absolutely weakening the area, probably 2x2" (or whatever the size of the grind area would be) by doing that. So Yes, the patch does make it weaker.
If it's REALLY coming through the sidewall, you have a tire that's probably allot more dangerous than you think.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
