down_home
Jun 25, 2016Explorer II
SCVJeff wrote:
One thing no one has mentioned is that on the interior sidewall, the impression of the cords is obvious. In order to prep that area they use an extremely hard wire brush to grind it flat for proper seal. Easy on the tread wall, it's 3/8"+ thick and the cords are buried deep. If you were to use that proceedure on a sidewall, you are absolutely weakening the area, probably 2x2" (or whatever the size of the grind area would be) by doing that. So Yes, the patch does make it weaker.
If it's REALLY coming through the sidewall, you have a tire that's probably allot more dangerous than you think.
Like you have said it would cut some cords. The patch no matter how you glue it to the inside it will not flex with the easy flexing sidewall. It will leak rather rapidly and could explode if it depressurizes at a fast speed.
Put a set or new expensive performance tires on a car. A few miles down the road a board or something with a big nail put a hole in the sidewall right next to the tread.
I tired to repair it myself since the tire dealer would not repair it.
It failed within a mile.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
