ulvik
May 06, 2016Explorer
firestorm79 wrote:
I highly recommend installing a fuel pump and using a boat tank. I sourced my own parts and installed it much like the bottom line trading kit with a few minor differences. Gravity fed systems look like hack jobs. Fuel pump system looks professional and you don't have to look for a way to elevate your tank.
Nothing like having 12 gallons of gas hooked up and if the tank runs low I can simply disconnect and switch to the internal tank without shutting off the generator.
If you don't mind me asking what was the part number on the fuel pump you are using? I would guess that the fuel pump pressure is very important because of it being a gravity fed carburetor. To me it would flood out the carb if the pressure is too high and it would starve for fuel if it is too low. any help with pump ID would be great!!!
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
