buta4's avatar
buta4
Fading Headlight Lenses
Hello,
Just a blurb on clearing up faded headlight lenses. Got a tip (third hand) that toothpaste rubbed over the plexiglass lenses will clear up the fading.
For what it's worth, there it is.
Regards,
  • I used Awesome general cleaner. It's a liquid in a spray bottle. Seems a lot of the yellowing is just dirt and grease. It did not remove all of it, but it got enough that the lights are bright again. Just spray it on and rub it with a coarse towel. Works good on all kinds of stuff, and it's only a buck at the dollar store.
  • tooth paste worked for me on my wife's 14 yr old sportage, al c.
  • JaxDad's avatar
    JaxDad
    Explorer III
    B.O. Plenty wrote:
    .Try fine (white) rubbing compound. It will work but it won't stay clear very long. Best to find some new replacements on E-Bay and just replace them...
    B.O.
    They don't stay clear because the UV protection on the surface of the lens has been buffed off.
    If you give them a coat of clear coat automotive paint they will stay clear a very long time.
    I did my F-350 lights about 4 or 5 years ago and they haven't started to haze up yet.
  • White toothpaste rubbed on with a soft cloth cleaned my faded Corolla lenses in a matter of minutes. Very little effort needed.
  • My lights turn yellow all the way thru the plastic so surface treatment does no goo. I don't mind the yellow because I installed HID lights and being dimmer is not something I mind and am sure others don't either.
  • Toothpaste has a VERY mild abrasive in it. If you rub toothpaste on them for a week or so you might notice a change..might not...Try fine (white) rubbing compound. It will work but it won't stay clear very long. Best to find some new replacements on E-Bay and just replace them...
    B.O.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
