Old-Biscuit
May 09, 2014Explorer III
Tacswa3 wrote:
Thanks guys. The TT is brand new and I've plugged it in here and there at home for the past week. Today its had the opportunity to be plugged in the longest its ever been (at least since I've had it). I just went out and unplugged it after 6-7 hours and the fan was not running. Does that mean the inverter finished charging the battery?
I've been meaning to disconnect the battery and put a trickle charge on it. Its brand new, but that doesn't mean anything.
When plugged into shore power the 'converter' will supply the 12V DC and charge the battery.
The fan runs to cool off converter due to heat produced....especially when charging battery
Only need to 'trickle charge battery if you are going to be unplugged for extended period.........several weeks.
Check the battery voltage and check water levels in battery.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
