TucsonJim
May 09, 2014Explorer II
If you have a light load on it, the fan may not even run. For example, if the batteries are charged and you only have a light or two on, you won't hear the fan kick on. But with a large load of charging or many lights, mine always cycles on to keep the converter cool.
BTW:
Converter = Converts 120VAC to 12VDC so you can run your 12 volt system and charge the batteries.
Inverter = An inverter changes 12VDC from the batteries into 120VAC so you can run 120V items such as a TV.
BTW:
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
