May 10, 2014Explorer II
Tacswa3 wrote:It was not running before or after you unplugged it?
Thanks guys... I just went out and unplugged it after 6-7 hours and the fan was not running...
If not running while plugged it >> All good, battery finally took a full charge.
If not running after unplugged >> It wouldn't run when unplugged.
If it's plugged in for day's and the fan is still running on high there may be a temperature sensor failure.
FWIW, mine is load dependent. Light DC load, no fan. The fan speed increases when load increases and decreases when load decreases.
TIP: When storing unplugged for more than a day either turn off the battery connection or remove it and place on maintenance charge. The parasitic loads of the camper (CO detector, radio clock, etc) will kill a battery.
Enjoy and Happy Camping
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
