- golf_bearsExplorerI turn the fan on to exhaust to the outside then take the air compressor and blow the dust and dirt out. If there's anything left on the screen I use a small wire brush and use the compressor again.
- FrankShoreExplorerThanks all!
- Old-BiscuitExplorer IIITry to rotate ring and free it up
Then apply upward pressure on screen while pulling down at curved area
Just has molded tabs on inside edge of screen that snap over frame. Takes a bit of force to remove - FrankShoreExplorerI'm pulling down on the little curved area and the rest of the ring isn't coming loose. What am I doing wrong? Thanks for any help. I really need to get this thing washed out and cleaned up!
lj2654 wrote:
mine are older and have to take 4 screws out is all...
Pop-N-Lock screens are available for replacement.
Ours were held in with screws but replaced them.
We use both Fantastic Vents a lot and would constantly have to clean 'cottonwood' off screens.
Pop-N-Locks made that job so much easier....no dropped screws down floor register, hiding in the carpet, hitting me in the face :B - lj2654Explorermine are older and have to take 4 screws out is all...
- dons2346Explorer
Old-Biscuit wrote:
FrankShore wrote:
I think my screens are pop out. Do they have to be aligned with anything before popping it out? Thanks
Nope.....
Should be a divet/scooped area on lip (thumb hold)
Yup. Put your thumb on one side of the notch and press up while pulling down on the notch. Makes it easier to remove the screen - Old-BiscuitExplorer III
Nope.....
Should be a divet/scooped area on lip (thumb hold) - FrankShoreExplorerI think my screens are pop out. Do they have to be aligned with anything before popping it out? Thanks
- MPI_MallardExplorerYou can buy the new snap-in screens at camping world that can be used on older fans.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
