wa8yxm wrote:
If your rig is 30 amp (Even if is not) there are two things you should buy.. Will try to find links to examples.
Since Camping world is part of the family that hosts this forum.. I use them first:
The needed adapter
The tester to plug into it.
NOTE: I'm sure I've seen that tester at CW but the link is to Amazon.com since I could not find it online at CW.
Before you plug into a 30 amp outlet,, Plug the tester into the adapter into the outlet and see what lights up.
I've got the 50 amp service on my rig. I've also got it on the 30 amp dogbone plug. My surge protector shows the same things as the tester.
