jffkrn's avatar
jffkrn
Fifth wheel Towing Help
While planning on an upgrade soon, weight ratings have me baffled. I have plugged in the numbers on some weight calculators and they come up short of what I can tow including the trailer I am towing now!!! But, it gets better, the weight ratings show I am fine towing what I am now and the scales show me way in the good also. So here is my dilemma. Tow vehicle is a gasoline 2010 GMC Sierra 4X4 extended cab regular or short bed manufacture GVWR of 9900, 3:73 ear ratio. I am towing a travel trailer at 6400 lbs now without any issues. So the plan to upgrade to a fifth wheel with a GVWR of 13900 and hitch weith at 1955. Manufacture shows a GCVWR of tow vehicle at 16000. Going through the checks and balances of different calculators and using all the info I have I come up short of towing the new fifth wheel. Now the question is how come everyone is pulling a large fifth wheel with the weight ratings that don't work or not within spec? I am not one to ignore the specs, but just about ready too unless I by a 2 ton truck! I am sure my truck will handle the weight etc, tow ratings jump with different gear ratio and / or diesel so the truck is the same, just mechanical difference so fuel mileage will suffer is the main issue only? Am I crazy or what? Honest input will be helpful. I will get with some folks at PD commercial enforcement to help as well. Your input is welcome and I thank you in advance.
  • jffkrn wrote:
    OK - So the actual numbers and info is /are:
    2010 GMC Sierra HD 25004 X 4, 3:73 gears, extended cab, 6 1/2 ft bed.
    owners manual says; Max trailer weight 9900 lbs 16000 GCWR
    actual scale reads with full fuel and passengers 6840
    front axle 3760 rear axle 3080
    door sticker gvwr 9200 fr ax 4200 rr ax 6084
    Trailer now that we are looking at is considered half ton towable with max gvwr at weighs in at 10320 uvwr 7550 hitch at 1520.
    calculating all we carry at 2000 lbs, (recalculated all) I think we will be ok? ! ? ! ? Your input once again is welcome. Good Luck & Be Safe ! ! !
    Should be good to go. 20% pin good 25% is close to max.
