amandasgramma
Oct 28, 2014Explorer
mlts22 wrote:We had our 5er up and ready to go today in 20 minutes. :) BTW -- we hit a record.....left at 9:30 with the rig to go to DMV (2 miles away), get licenses and vin verified, and back and set up in 1 hr and 40 minutes.....yeah, a DMV that's fast!!!! I believe the setting up and taking down is totally personal. One person doing it, 10 chairs around the camp, pit fire, BBQ, yeah, it'll take longer. We find it doesn't take any longer for a 5er than a MH and hooking a toad (btw..be sure to add time if the toad is on a dolly) :) :)BB_TX wrote:
To me it comes downtown how much you intend to travel. If you intend to move a lot and put a lot of miles on it, then MH. If you are more likely to stay a long time at each destination and only travel a relatively few miles each year, then 5er.
X2.
The only exception is the fact that with a MH, one can get a high MPG toad, so when the "A" is parked, running around an area isn't as bad.
However, there is always that rule of thumb -- if moving around often, a class "A" + toad. If staying in one place, the fiver and a one ton.
The reason is that it is a lot easier to go from camped to on the road with a class "A". Pretty much disconnect cables, pull slides in, lift jacks, hitch the toad, and be off. On the road, one can pull in a parking lot with an "A", and take a quick nap, harder to do than with a 5-er. Hitching and unhitching a trailer can take 30-45 minutes, and it is a process that cannot be hurried (lest one forget some doodad sticking out and cause thousands to tens of thousands in damage.)
If camping more than on the road, a trailer is better, because it is one less motor and drivetrain to keep maintained, fluids topped off, and registered.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
