coolmom42
Dec 29, 2015Explorer II
You shouldn't have a problem. Your water will be well above freezing when you fill, and the temps will only be below freezing for maybe 8 hours at the most. The most likely spot to freeze is the line between the water tank and the pump, so don't run the pump until temps are warmer.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
