brirene
Dec 29, 2015Explorer
I don't think you'll have a problem either especially once the water begins to move around when you're underway. If it were me, I might run my furnace for an hour or so late Friday. If you do that, it's doubtful that your actual water temp would even approach freezing at those temps, let alone freezing solid, which is what you want to avoid. As mentioned and you've indicated, don't run the pump.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
