- tvman44ExplorerA whole house filter from Lowes or HD connected at the spicot ahead of the hose for whole house filtration. That is what we do. :)
- Robin1953Explorer
Wilson123 wrote:
Any advice on a water filter system? Either at the hookup or at the sink. I'm in a spot with a lot of iron.
I use a double filter system. I got two of the GE brand whole house filters from Lowe's. I use a sediment filter in the first one and a charcoal filter in the second filter. Got the brass fittings to go from 3/4" pipe to garden hose there as well. I bought the more expensive clear filter for the sediment filter since I wanted a visual on it to know when I need to change it. Replacement filters are about $5 a piece. I think the clear filter was like $30 and the other one was like $20. Just remember that this will cause your water pressure to drop somewhat. HTH - mlts22Explorer II
Perhaps both? I like using the inline Camco water filters on a 10' length of potable water hose (so it doesn't put weight/torque on the fill or city water inlet.) Then, one for the sink. The Camco filter works as a prefilter if one has as an inline system, and does a great job at removing stuff. - 1492ModeratorMoved from Forum Technical Support
- ChooChooMan74ExplorerOh, I thought you wanted to filter something in the forum, as this is Technical Support for the Forum. Because the search feature has a filter button where you can just search the particular area instead the whole site. Or, you can use the advanced search feature.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
