et2
Mar 15, 2014Explorer
If you have a 2014 Jeep Cherokee Trailkawk take note if installing a Blue Ox base plate. On the drivers side there is a hole needed to be drilled through the cars frame. Directly behind where that hole goes is the transmission cooler line. If you or the installer isn't careful you can damage it. Happened to ours.
Also take note of the transmission cooler. Some notes from the repairing Jeep dealer indicated the transmission cooler rubs the Blue Ox base plate installation. It had to be removed to get to the line for replacement.
Just a FYI.
Just a FYI.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
