handye9's avatar
handye9
Explorer II
Jun 11, 2013
Finally hit the scales
Have had various truck / trailer combinations, for 15 years, and finally weighed one.
Trailer numbers from manufacturers sticker
UVW 7021 lbs hitch weight 841 lbs (12%)
It's a front kitchen model. Grocery weight would be up front. Fresh tank is behind axles, thus, water weight would counter grocery weight.
Loaded with verything except water and groceries, here are scale numbers.
Truck Alone (08 F250 Crewcab gas 4X4 with Timbren SES on rear)
Front 4240 wheel well height 41 1/4 inches
Rear 3440 wheel well height 43 inches
Total 7680
Axle ratings 5600 front, 6100 rear
Truck and trailer with WDH
Front 4000 wheel well height 41 3/4 inches
Rear 4740 wheel well height 42 1/4 inches
Trailer 7320
Total 16060
Truck and trailer with WD disconnected
Front 3800 wheel well height 41 1/2 inches
Rear 5060 wheel well height 41 1/2 inches
Trailer 7200
Total 16060
With and without WDH, wheel well height doesn't change more than 1/2 inch in front and 3/4 inch in rear.
My calculations:
Trailer and hitch weigh 8330 lbs (16060 - 7680)
Trailer without WD takes 440 lbs from steering wheels, WD puts 200 lbs back. Front axle load restoration about 49%. From what I understand, Ford recommends 50% FALR.
Trailer without WD adds 1620 lbs to rear axle, WD puts 320 back on trailer.
Tongue weight 1300 lbs and hitch redistributes 520 lbs.
Am I calculating correctly?
I am confused. I used a tongue weight scale in the driveway. It showed 1000 lbs tongue weight. While filling fresh (located behind axles) tank, I watched it drop to 800 lbs. Maybe tongue weight scale is wrong?
  • No, unless I'm misreading the numbers you posted it appears that you made the front end lighter by 200 pounds. And made the rear end heavy by nearly a thousand pounds. I would prefer to have the front end about equal both unloaded and loaded. That way there is no handling issues.
  • donn0128 wrote:
    Looks to me like you need to add about 400 pounds to the front and unload the rear. As much as you have unloaded the front of the TV I suspect it will become squirrely at highway speed.
    It handles fine.
    Are you saying WD hitch should add 400 lbs more, to front axle?
  • Passin Thru wrote:
    After rereading this I feel like you are putting too much into it. Make sure you Pickup is level and you are fully loaded and weigh it again. It won't hurt to have 700 lb more on the rear axle of the truck. It may have an extra spring. Go drive it and see how it handles. You are within limits so don't worry so much. There are tolerances.
    Not worried. Curious as to why I get different numbers between tongue weight scale and CAT scale, and whether or not I'm calculating correctly.
  • Looks to me like you need to add about 400 pounds to the front and unload the rear. As much as you have unloaded the front of the TV I suspect it will become squirrely at highway speed.
  • After rereading this I feel like you are putting too much into it. Make sure you Pickup is level and you are fully loaded and weigh it again. It won't hurt to have 700 lb more on the rear axle of the truck. It may have an extra spring. Go drive it and see how it handles. You are within limits so don't worry so much. There are tolerances.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 16, 2025
