ReneeG's avatar
ReneeG
Fire Alarm Sensitivity
Couple of things on the sensitivity of fire alarms. I know they are made to detect the slightest smoke, even before we see it, but ours often goes off when I make muffins and a slight drip of the batter on the pan burns. DH stands up by it fanning it with a pot holder and that stops it. How many of you have to do this too? My poor Mica, goes running for a place to hide when it goes off. With it's sensitivity, is a toaster going to set it off? We've been RV'ing in various towablesl for close to 20 years and have been making toast under the broiler, so I thought I would buy a little inexpensive two slice toaster. Is it going to set off the alarm with all those little bits of crumbs that are going to burn? I'm debating whether continuing to broil my toast.
  • Try a photoelectric smoke detector near the kitchen, and move the other one to say the bedroom.
    A photoelectric detector waits for more smoke before going off. However very high humidity can set it off. . . It should not be over a pot of boiling water. . .
    It uses a LED light and photo receiver (like a solar panel) that detects that light. When there is so much smoke that the light is blocked, then it will trip the alarm. . .
    Good luck,
    Fred.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
