Mountain_Mama
Jun 06, 2013Explorer
Fire Starters from RV Travel tips question
"Fire starter tip
Need fire starters? Reader S. Fox sends us a suggestion from The Old Farmer's Almanac: Start with dried pine cones. Melt old candle stubs in a double-boiler. Dip the pine cones into the hot wax. Let dry, perhaps on a cookie sheet lined with aluminum foil. Store when dry. The wax helps the pine cones burn long enough to help get your fire going. For special effects, soak the dried pine cones for 24 hours in a solution of 1 pound Epsom salts to 1 gallon water. The treated dried cones produce a myriad of colors in the campfire.'
I just read the above on the daily RV Tips from rvtravel.com. Has anyone tried soaking the pine cones in the epsom salt & water? If so, is it best to soak them before dipping in melted wax after they've dried, or after, or does it matter? :h TIA!
