skipnchar
Jun 26, 2013Explorer
Your rig LOOKS to be fairly well set up, from the photo. Leveling is not required to be perfect and you're looking quite level. The Push/pull from being passed by a truck is more a product of your sway control than the WD system. In EVERY respect you'd do well to upgrade your friction bar to an integrated anti sway system (Reece duel cam or Equalizer). The duel cam can likely be retrofitted to your current hitch but the Equalizer would require a complete new system. Either one would be well worth the effort or expense.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
