mosseater
Jun 27, 2013Explorer II
dodge guy wrote:dodge guy wrote:
The porposing usually comes from insufficient tongue weight. were talking as little as 50-100lbs. you need to know the ready to travel trailer weight so you can get the proper tongue weight (12-13%) and then be sure you have a WD system rated for your loaded tongue weight.
Or an over adjusted WD hitch, and/or an oversized WD hitch.
In my case, with about 1100 lbs tongue I'm over 13% on a 34' trailer, so I'm guessing my porpoising, though not excessive, is mainly softly sprung F 150, and/or not enough shock dampening, and more likely the latter. Probably not the case with the OP's setup given the trailer length/tongue weight. I'm betting light tongue.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
