Houstonkid's avatar
Houstonkid
First time towing w/EQ, question
I got my Equalizer set-up and my wife and I went to a local campground with our new trailer for our first shake down trip.
I set everything up per the instructions, using 5 washers, and the truck/trailer are pretty dang near level.
I had to jack my truck up really high and still use the provided cheater to get the bars on. When I retracted the tongue hitch the bars were somewhat swayed.
Also, when making sharper turns I could feel the vibration of the hitch in the floor board of my truck.
Is it possible for these hitches to be set-up too tight?
I bet you guys thought I was going to ask if my hitch was supposed to be this loud :) It will definitely wake a campground up!
  • How did it feel when towing..I'd try less tension on the bars (hang one less chain link).
    Your numbers don't seem right to me. I'm guessing you have more than 900 lbs of tongue weight...just a guess.
  • Thanks JM, my main concern is the appearance that the bars were swayed and that I could feel the friction in the frame of my truck. Here are my spec's
    Equalizer 14000/1400 Hitch
    TV
    2012 F250 4x4 Diesel
    TT 2013 Primetime Lacrosse
    35'
    8000#'s
    900# TW
  • I got my Equalizer set-up and my wife and I went to a local campground with our new trailer for our first shake down trip.
    I bet you guys thought I was going to ask if my hitch was supposed to be this loud It will definitely wake a campground up!
    It would help to learn what size hitch you have, the tow vehicle and the trailer weight and model. But, to answer your question it can be set too tight. It creaks and pops, that is normal.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
