The_LeRoys's avatar
The_LeRoys
First time towing with the new van, not fun!
So I got to tow with our new van for the first time today. It was one of my worst experiences towing ever. The engine and transmission seemed to run great, but the steering was miserable.
To be fair, my hitch isn't adjusted quite right for the van, its still setup for our truck, but the hitch heights were similar so I figured I could drive it home as is then adjust. We have the equalizer hitch and it has been awesome on this camper and our previous one. It needs to add a bit more weight onto the front wheels. Its not off by much probably 1 hole, but I know its not perfect. THere was some weight on the bars but not a ton.
My tires are brand new Michelin LTX MS2 tires and my alignment was checked and really good. On the road not towing it goes pretty straight downt he road.
When the road was in good shape and straight it seemed to go along pretty well, not as good as my last truck but not unbearable. However as soon as I had to make one steering correction, I ended up having to make about a dozen more to get it straight again, with my tail wagging all over. When the road was uneven (construction zone) or in bad shape, I felt like I was all over the road. If a semi passed me on level ground, there wasn't any sway or pull really felt. BUt if they passed me on the uneven section, it was miserable. A curve in the road when it was uneven was about as bad as you could get. I just felt like I spent the entire time zigging from one side of the lane to the other trying to keep it straight the whole drive.
I wont get a chance to adjust the hitch and try again for probably a week, and we leave for our big trip in under 3, not leaving me much time to correct any issues.
Could not having the hitch perfect really cause me that much misery? Or are there other things I need to be considering? That hitch has been amazing on the same camper and other vehicles in the past.
I remember when we went from a 1/2 ton van in the past (on a different trailer) to a 3/4 ton suburban thinking the towing was night & day better. Is it just towing with a van that is different? Or should I be considering adding something? AntiSway bars to the front or rear axle of the truck? Steering system like Roadmaster?
Thoughts / Suggestions?
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
