The_LeRoys's avatar
The_LeRoys
First time towing with the new van, not fun!
So I got to tow with our new van for the first time today. It was one of my worst experiences towing ever. The engine and transmission seemed to run great, but the steering was miserable.
To be fair, my hitch isn't adjusted quite right for the van, its still setup for our truck, but the hitch heights were similar so I figured I could drive it home as is then adjust. We have the equalizer hitch and it has been awesome on this camper and our previous one. It needs to add a bit more weight onto the front wheels. Its not off by much probably 1 hole, but I know its not perfect. THere was some weight on the bars but not a ton.
My tires are brand new Michelin LTX MS2 tires and my alignment was checked and really good. On the road not towing it goes pretty straight downt he road.
When the road was in good shape and straight it seemed to go along pretty well, not as good as my last truck but not unbearable. However as soon as I had to make one steering correction, I ended up having to make about a dozen more to get it straight again, with my tail wagging all over. When the road was uneven (construction zone) or in bad shape, I felt like I was all over the road. If a semi passed me on level ground, there wasn't any sway or pull really felt. BUt if they passed me on the uneven section, it was miserable. A curve in the road when it was uneven was about as bad as you could get. I just felt like I spent the entire time zigging from one side of the lane to the other trying to keep it straight the whole drive.
I wont get a chance to adjust the hitch and try again for probably a week, and we leave for our big trip in under 3, not leaving me much time to correct any issues.
Could not having the hitch perfect really cause me that much misery? Or are there other things I need to be considering? That hitch has been amazing on the same camper and other vehicles in the past.
I remember when we went from a 1/2 ton van in the past (on a different trailer) to a 3/4 ton suburban thinking the towing was night & day better. Is it just towing with a van that is different? Or should I be considering adding something? AntiSway bars to the front or rear axle of the truck? Steering system like Roadmaster?
Thoughts / Suggestions?
  • If the back of the van isn't following the front you may need a four wheel alignment to make sure both axles are parallel. Worse case is that the van was in a wreck and is tweaked out of shape. The four wheel alignment can help there, too.
  • I have installed the exact same tires on my last 3 tow vehicles and loved them, never experiencing anything like this. Some of the tires I towed a camper the same day or next day after they were installed, not waiting 600 miles.
    After WyoTravelers suggestions of the track bar I did a bit of reading and it does sound like a logical suggestion. Especially after reading the below post by Ron.Dittmer.
    E350 Susupension Modifications
    After discussing the Track Bar with the wife she mentioned that when she was following the van the other day she noticed that the back of the van wasn't really "following" the front, it appeared that the back end was a bit to the right of the front. This was before we got the new tires though. Does that sound like it could be the track bar? Or something else?
  • The LeRoys wrote:
    ....My tires are brand
    and my alignment was checked and really good. On the road not towing it goes pretty straight down the road......Thoughts / Suggestions?
    Take two fingers and grab the outer tread on the front tires and move it back and forth. My bet is,it is going to flex back and forth like nobody's business.
    Had perfect handling on my RV until I put the new Michelin's on and we were all over the road......to aggressive of a tread.
    I had that MH in 4 shops trying to figure out what was wrong with the 'handling'. The 5th shop was a semi-truck repair. Mechanic walked right out to the tires and showed me why. :(
  • I found that you need about 600 miles for the tires to tighten up. We have these on our RV and they squirmed badly at 1st. Same thing for the tires on my F350, new BFG's, took about 600 miles for them to tighten up. After that they were ok, now yes you may need to reset the hitch, might also need to add airbags who can tell?
  • I would be checking track bar for your van. Does it have coil springs in the rear?
