Fastfwd75's avatar
Fastfwd75
First trip. Lost a light cover. Silicon or other trick?
Lost the cover while rolling. Other side is very easy to remove by hand but does not seem like it would fall off just from a bump in the road.
Buy new one and fix with silicon or is there a better trick out there?
  • When working around my sidelights the lens would fall off. Found replacements and they snapped on tight. I now have a lifetime stock. If one gets loose just replace it problem over.
  • Lost several of these! Use silicon calk around the top and sides only. This way if water does get inside it can drain out.
  • Mine is cracked, but it hasn't fallen off. I'll be a little clear silicone caulk would keep it on.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
