JIMNLIN
Nov 26, 2016Explorer III
fj12ryder wrote:
If the jaws don't lock around the pin you can't pull the trailer, it just pulls out of the jaws.
If it was high hitched the jaws can still be closed and may even pass the tug test. Under the right conditions any conventional 5th wheel hitch can be hi pinned....even the OTR pro grade Fontaine or SAF Holland or the Holland Binkley.
With 3000-3500 lbs (pin flange) siting on top of the hitch jaws it may even make it down the road aways till the pin slide off the hitch jaws. Most of the time the pin slides off the jaws on the first turn or two.
The OP had quite a ride. Glad all of his are ok.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
