rhagfo
Nov 28, 2016Explorer III
MtnMike wrote:
There seems to be a lot of speculation about what happened. The hitch was hitched correctly. After separation, the jaws were still locked, the latch bar was in place, pinned and clipped. Two different highway patrolmen and the tow truck operator inspected the hitch and all appears to be as one would expect. One poster theorized that it may have been high-hitched. The plate of the fifth wheel and the pin plate on the trailer would be separated. If somehow it would actually be possible to pull away without noticing the gap, with the pin on top of the jaws, there would be evidence on the closed jaws such as paint scraped and eroded from the improper placement. The only such wear is between the jaws. The hitch is less than two months old so worn hitch components is not the issue. I will have the hitch and the installation reviewed for faulty parts or improper installation, before I use it again so I can be reassured that this will not happen again. Although the investigating patrolman indicated the installation appeared to be correct and was extremely solid and secure. As an engineer, I know that nothing is fool-proof. New parts sometimes fail and human operators occasionally make mistakes.
Well 6 pages, and general thoughts are, you were not hitched correctly.
I personally find it hard to believe the jaws opened then closed with the locking handle closed and pined!
If you the OP are 100% positive you had the pin captured in the jaws before taking off (did you look at the pin in the jaws), I would be on the phone to B&W to arrange to have the hitch picked up and shipped back to them for examination, would also like to see pictures posted as the is a very hard to believe story.
Sorry for the shock and damage from the drop, just hard to believe the story.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
