AlwaysDreaming's avatar
Mar 22, 2018
Flat Tow vs Tow Dolly
I bought a 2016 Ford Fiesta which according to Ford can be flat towed (4 Down) as long as you keep it under 70 MPH. The car weighs 2600 lbs. I am considering towing methods with my RV.
The RV is a Class C 22ft with a Ford E450 Chassis (Thor Chateau).
It appears to me that using a Tow Dolly (2 wheels down) would be easiest especially if I need supplemental braking system.
What is the advantages/disadvantage of Tow Dolly vs. Flat Tow?
Do I need a supplemental braking system for 2600 lb. car on a Tow Dolly?
Hydraulic Drum Surge Brake seems to be he simplest and most reliable system for a Tow Dolly compared to electric brakes on the Tow Dolly?
Any experiences with Hydraulic Drum Surge Brakes on a Tow Dolly?
Thanks for reading
  • If possible, flat tow. My opinion, based on doing the same research you're doing. It's easier, sometimes pricier, but a lot less hassle.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
