AL28's avatar
AL28
Flat towing 2014 Ford Taurus
I recently purchased a 2014 Ford Taurus SEL with the 3.5L engine. The manual indicates it can be flat towed. I do not have the 7" display or the keyless ignition options.
However, the manual is incomplete as to the instructions and I have not received anything from Ford on the full procedure.
So if anyone is towing this car, if you have any additional info, I would appreciate it.
Basically the manual states to start the car, put it in D, then R, and finally in N before towing. It also states to start the engine every 6 hours.
While the manual does not state it, the inference for starting the engine would seem to indicate to shut the engine off while towing.
However, do you leave the ignition in ACC or OFF? I would assume ACC as I am also assuming the the steering wheel should not be locked I don't think.
And are their any fuses that need to be pulled to prevent the battery from dying?
Any other tips or information would also be appreciated.
  • I was able to get some additional info from Ford Customer Service that the key should be in the ACC position.
    I was sort of able to confirm this by looking up other Ford models with the same engine/transmission combo (which I would think might have use the same procedure), and one of the other models indicated to put the vehicle into ACC position - but no mention about fuses.
    They also said that there are no issues with a dead battery if you start the car as prescribed (every 6 hours), but I am a bit skeptical about that.
    I would like to know if there are any other Taurus towers (probably only one or two people) that pull fuses.
  • Yes, the engine should be off.....and if the steering wheel is unlocked when you turn the key to off, then it doesn't need to be in ACC. I would definitely check this before actual towing. The steering wheel needs to be UNLOCKED during towing or you'll destroy your front tires.
    Some vehicles you can turn the engine off and leave the key in "off", but NOT pull the key out and the steering wheel will stay unlocked. Once you pull the key out, the wheel will lock. However, when the key is in the "off" position, it is then released and can actually fall out of the ignition due to vibration when towing. Best to leave in ACC. Unfortunately, leaving the key in ACC can actually leave power on to some accessories...radio, nav, etc and can/will drain your battery. That's why on some vehicles you have to pull a certain fuse that will turn off the power to these accessory items.....some you have to pull the neg cable off the battery itself.
    I have no experience with a Taurus, so hopefully someone who has will add more to your post.
    Ron
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
