Mtnbikerx's avatar
Mtnbikerx
Flat towing advice
Purchasing a 2012 Winn Journey with the 360 Cummins. It already has a Blue Ox tow bar. We will be towing an AWD ML350. Before digging into the owner's manual of the Benz I would like some comments regarding safety and maintenance of both vehicles. Would a trailer for the toad be a better plan?
  • the first thing you should do is read that owner's manual for "valid" information. what does that say under either recreational towing or towing behind a motorhome. only if that gives proper directions to do so, should you be asking those other questions.
    bumpy
  • It probably will be impossible to find a base plate for any model of a Benz to tow it 4 down. Even if the manufacture recommends pulling it 4 down. Which I would guess they don't.
    Get a light trailer. Even then hope your Winn can pull over 5K lb.
    That is the reason I went with the Lincoln MKS AWD Ecoboost. It can be pulled 4 down.
