HuntMakDad's avatar
HuntMakDad
Flat towing GMC Yukon Denali Hybrid 4WD
Hi;
Does anyone have any experience or knowledge regarding flat towing a 2011 Yukon Denali Hybrid 4wd? I purchased one for this reason and outfitted in with Demco base plates. The owners manual says to put the transfer case in neutral, put the transmission in park, turn the ignition switch off and remove the key. When I attempt to tow, the front wheels do not turn freely at all. They bind and put a lot of strain on the brackets even bending them slightly. I have made 2 separate 500 mile trips but it doesn't seem correct. We had a 2009 Suburban 4wd we flat towed the same way and never had a problem. Wondering if it has something to do with the steering column locking up. Any assistance would be greatly appreciated. Thanks
  • GM stopped installing a steering locks in their trucks in 2002, so there is no reason to check for one. I would call the special customer service number in your manual and ask to speak to a trained technician about the problem. A Hybrid is a whole different animal than the normal 4x4 system.
  • I will try both of those suggestions. Thank you for the response. We have been flat towing vehicles for years behind our rig and never had any issues. This one just doesn't feel safe. Thanks again.
  • Have a trusted mechanic check the steering for a lock mechanism. If it is there, have him (or her) remove it and dispose of the parts.
    It is not required by law, and you don't need it and for towing you don't want it!
  • HuntMakDad wrote:
    Yes, that's exactly what I have been doing and front wheels still bind. Wondering if leaving ignition key 1 click forward to release steering column from locking may solve issue. Thanks for the response.
    Can you remove key with it in that position....nothing turned on that would drain battery?
  • Yes, that's exactly what I have been doing and front wheels still bind. Wondering if leaving ignition key 1 click forward to release steering column from locking may solve issue. Thanks for the response.
  • Transmission on 'PARK'
    Transfer Case in 'NEUTRAL'
    Parking Brake OFF
    Ignition key to LOCK/OFF position and remove
    When you turn key to LOCK/OFF position steering wheel should still be able to turn freely.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
