HoJoPo
Feb 29, 2016Explorer
Jeep Commander and the current generation Dodge Durango (both based on the Grand Cherokee) have third row options and should be flat towable in 4WD trim, if they have the low range transfer case with neutral. There were AWD options without low range that are not flat towable, so you need to check and make sure it has a neutral position.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
