lanerd
Jul 24, 2015Explorer II
I don't think you would want to tow any vehicle with flat wheels....do you? :p:E
That said, I'm sure you're referring to towing a vehicle with all four wheels down as opposed to a dolly with two wheels up or a trailer will all four wheels up.
Many, many of the domestic vehicles with auto transmissions are capable of being towed 4-down; however, there are few import vehicle that can. GM, Ford, and Chrysler all have lots to choose from.
If you have a particular vehicle in mind, you can go to: REMCO and plug in the info needed and it will tell you if it can be towed 4-down or requires a transmission lube pump or a driveshaft disconnect.
I noticed you posted in the Class C forum. Please be aware that most class C's are weight limited to a max of 5000 pounds (and some only 3500 lbs) towing. Check your owner's manual for this info.
Good luck in your search...
Ron
Ron
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
