Considering the Flojet system for dumping at home into our septic clean out. Our clean out is behind our home and no way to get RV close to it. I saw a thing from the manufacturer that with a 3/4" hos...
I used one last year at a friends house. He had a 100' 3/4" hose and it would trip the circuit breaker after about 5 minutes. This was all on level ground.
If you really want this to work for you, you should forget the 3/4' hose and use 1.25" PVC pipe. I would also replace the 12 gauge wire with 10 gauge.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
